Controlling Scroll Text Properties
I have a string indicator with a scroll bar on the side.  Each line that is written displays underneath the previous line.  However, when it gets to the bottom (8th line), it does not auto scroll up.  Therefore, I have to use the scroll bar to see what was last written.  Is there a property that allows me to control this so that the last item added always displays?
Message 1 of 10
(5,625 Views)
there is a property 'Text.Scroll Position'. Wire -1 to it to show the last line of text.
UliB
Message 2 of 10
(5,611 Views)
Set Text.ScrollPos to the number of letters in your indicator, and the scroll position will move to the last line.
If you do not know the number of letters, read Text.Text and find the string length.
Message 3 of 10
(5,606 Views)
I read about the -1.  However, the type is U32 and it won't let me use the -1
Message 4 of 10
(5,594 Views)
-1 will cast to the maximum size of U32, which will have the same effect as setting it to the length of the text in the indicator.
But I think setting it to the actual length is more correct since it does not hide what is actually happening.
Message 5 of 10
(5,586 Views)
Well,
-1 in I32 will convert to 4294967295 in U32. If you always want the last line wire a I32 constant with -1 to the property.
UliB
Message 6 of 10
(5,584 Views)
I tried some of the suggestions, and they don't seem to work.  One question, though, can I set the Text.ScrollPos attribute once (at the beginning) and be done? Or do I have to set it each time I write to it?
Message 7 of 10
(5,543 Views)
The property node updates the display when you call it, so you should call 'Text.Scroll Position' every time after you updated your text.
You could use property 'value' and property 'Text.Scroll Position' in one property node.
UliB
Message 8 of 10
(5,531 Views)
It could be like this:
UliB
Message 9 of 10
(5,519 Views)
That seems to work now!  Thanks for all the help
Message 10 of 10
(5,496 Views)
