Controlling Valves with a Producer/Consumer structure
Hi all,
 I 've been working in a research where temperature and pressure can cause serious material failure. I've made a sequence in a text file of 0's and 1's with a time column in it. I've been using a program where labview reads this text file and starts controlling the valves by itself. The problem now is to add a maximum temperature or pressure value for the labview program to run an "emergency sequence" if the measurement exceeds this limit. I've been trying to use this program with a DAQ Assistant in a while loop but I've been having problems with it.
Someone suggested me that I should use a Producer/Consumer architecture to do this, but the problem is that I've been working with LabVIEW for 2 months, so I am not an expert. I wanted to see if anyone could help me build this program with such architecture.
(2,814 Views)
Hi gmartinez,
Here is a great example of using a producer consumer architecture while acquiring data.
https://decibel.ni.com/content/docs/DOC-2431
You will want to model your VI after this except instead of writing the data to a file in the consumer loop, you will want to check if the data is out of range and then execute your 'emergency' code sequence. A case structure inside the consumer loop would be a great way of achieving this. If you want to see the design pattern you can also go to
 File->New....->VI->From Template->Framework->Design Patterns->Producer/Consumer Design Pattern(Data)
in LabVIEW.
DylanC
(2,784 Views)
Hi Dylan,
I was trying to open the vi in my LabVIEW 2009 and it said that the file is not a resource file and that it couldn't be loaded. Any suggestions?
Gus
(2,770 Views)
Hi Dylan,
I got the program running but had some trouble with it, so I modified my other program but now the problem is that the DAQ Assistant reads just one sample and stops reading them continuously. I wanted the DAQ Assistant to continue reading but I am not sure how to do that. Any suggestions?
Attached is my program.
(2,761 Views)
