Controlling Variable Frequency Drive (Optidrive E2)
Hi Folks,
I am currently a student and working on a project where I need to control a motor speed through Optidrive E2, which is connected with CPU through speedy and Ethernet cable. I am wondering if someone has already worked on something similar? Is it possible to control the VRF (variable frequency Drive) by LabVIEW through speedy.. ?? Speedy is a device by Driveweb.. https://driveweb.com/speedy-embedded-automation/
Thanks in advance!!
(3,423 Views)
Hi  Singh_Chahal,
It depends a lot on each application, but I found a forum that may be helpful,
https://forums.ni.com/t5/LabVIEW/how-can-i-control-a-Yaskawa-V1000-variable-frequency-drive-with/td-...
I am going to research and check if I can find something else that might help us, let me know how your application progress!
Regards
(3,388 Views)
