Controlling a 220VAC solenoid valve coil with PWM
Hello !
I have the cDAQ-9185 Chasse in our lab, and I need a C module or a driver(if applicable) to control a 220 VAC valve directly with PWM.
I will be using the "Signal Simulation" to input a square signal and changing the duty cycle from it to generate a PWM signal simulation as an input. Will this work ?
I was looking to use NI-9481 module for this purpose, will it work ?
It is a 3 Wires cable (1 of 3 is Neutral)
Ata Alkhatib
(1,057 Views)
Accepted by topic author ataalkhatib97
@ataalkhatib97 wrote:
Hello !
Ata Alkhatib
Not directly because a PWM signal would be a pulsed DC at logic levels not 220Vac.
You might be able to drive a Triac circuit or possibly solid state relay with the PWM output and use that to drive the 220Vac for the valve.
=== Engineer Ambiguously ===
(1,036 Views)
Thank you!
(1,025 Views)
