Controlling a system using knobs.
I would like to design a system wherein a value increments itself on every complete clockwise rotation of a knob and decrements itself on every complete anticlockwise rotation of the same knob.
(3,546 Views)
Are you talking real physical knobs like in a multiturn potentiometer or encoder?  And if so, is it a potentiometer or an encoder?  Or are you talking about a knob like you would drop onto the front panel of LabVIEW.
(3,544 Views)
i have attached a vi which will increment and decrement the value of a LabVIEW knob as you have told. And as Ravan has told, if its a physical knob, let us know what type is it. May be, making a little changes in the attached vi would work in that case as well.
Nitz..
(Kudos are always welcome;))
(3,521 Views)
Let us know if your problem was solved by marking it. And also feel fry to ask if you have any further doubts.
Nitz
(3,473 Views)
