Controlling another vi by pressing a button in main vi labview
I want to control a boolean button from main vi and this button will change the indicator in another vi. Actually, my work is about changing languages, when i press the button, front panel lang. is changing, I have also another vi and there is a button too for changing lang. I want to use one button in main vi and the button will change language of the other vi, too. I don't know exactly the subvi structures. I tried several solutions but no result. How can i do this application.
Thanks a lot!
(2,460 Views)
Hi caki,
use a wire from your main VI button to the connector pane of those subVIs…
(2,447 Views)
Thanks for reply, i already tried this. When i wire the button to subvi, click the button then I can't do anything on the front panel, so I have to stop vi.
(2,433 Views)
Start SubVI asynchronously
and then use something like action engine (what i usually use, but i hear it's not example of good practice anymore) to pass information between main vi and subVI.
(2,424 Views)
Hi caki,
so you did something to some VIs unknown to us, but you want us to debug your problem?
Why don't you attach your VIs?
(2,421 Views)
Accepted by cakiroglu
These are the vi's. In main vi I wired sub vi directly to button. It changes graph vi but then freeze, so i have to stop vi.
(2,416 Views)
