Controlling bechoff IPC using a local labview application
I am using a Beckhoff CX1000 IPC to interface between an AB PLC(via device net) and a device(via rs232. The IPC is running windows CE.net and currently the software is developed usind twincat. I had developed a test program using labview and ideally would like to run my app on the IPC. The IPC has flash card storage. I know beckhoff have made available a active x control however i know nothing of developing this on an IPC. Any ideas would be great
Message 1 of 1
(3,979 Views)
