08-11-2009 02:37 PM
Hey everyone, thanks for the help!
I thought no one had answered and just today, I got an e-mail telling that there were answers here.
As I'm using a laptop, there's no parallel port. Therefore, I think the best way for me would be to use the way Alain S posted.
However, I figured out a way to do the entire thing without using Labview, using only microcontrollers. If that doesnt work, I'll probably try making my own DAQ card/system.
Anyway...thanks a lot for the answers!
I'll probably use some of those ideas in future projects..
08-12-2009 02:36 AM
Mardukker wrote:However, I figured out a way to do the entire thing without using Labview, using only microcontrollers. If that doesnt work,
That will work ![]()
And if it doesn't it's because the code inside the µC is wrong ![]()
If you didn't select a µC yet you can consider the PSoC, analog & digital processing in one chip.
08-12-2009 08:46 AM
Coq rouge,
Measure temperature with a sound card = {Get a cage of crickets. Monitor the cricket chirp rate. Calculate temperature from rate.}?
Lynn
08-12-2009 09:08 AM
08-12-2009 09:52 AM
