Controlling external equipment over GPIB using LabView
The instrument and the commands and the GPIB bus do not support simultaneous settings of two different channels. You have to do for example, "VSET 1,2.000000V;ISET 0.130000A;", followed by "VSET 2,2.000000V;ISET 0.130000A;". The driver does this with the Set Voltage/Current function you have in your example. You should have two of these functions in your VI instead of one Set Voltage/Current and one Application Function VI. You might be able to speed thngs up by using the Store/Recall function to retrieve a specific setting where both outputs are configured. There is still the possibility that the outputs will turn on a slightly different times. The user manual should have that information.
Message 11 of 13
(865 Views)
Thanks for the support. I will try this option and get back to you.
thanks
Janit
Message 12 of 13
(860 Views)
Thanks for the help, I am bale to control through GPIB commands.
I have one more problem, I need to do DNL & INL analysis of the ADC output.
Can you suggest, how to do this.
thanks
Janit
Message 13 of 13
(852 Views)
