Controlling lisbox scrollbar programatically
Is there any way to control listbox scrollbar programatically such way that the first listbox's scrollbar moves also the second listbox scrollbar (or prefer moves values in listbox 2). I wouldn't like to use multicolumnlistbox in this case, because user should have the possibility to check the values from both columns separately.
(3,318 Views)
Hi Janne
You can link the scrollbar positions using the TopRow property node.
See attached jpg.
Regards
Neil
(3,316 Views)
Thanks! It works.
(3,312 Views)
