Controlling open office with active X
hey ,
I want to use the active X control to use open office calc on my front panel . I come up with a solution to use explorer to open the openoffice calc on the front panel but i cannot edit it. see the attached vi . remember you need to have open office in you computer and also to give the link of url in the block diagram from where your file is
Regards
Ali
Regards
(3,412 Views)
Hello Ali
This has been asked several times, you may search the forums as several approaches has been used in the past:
https://www.google.co.cr/#q=site:forums.ni.com+open+office+labview&hl=es-419&tbo=d&ei=qoazUK2LD4bc8w...
Regarda
Mart G
(3,377 Views)
yes , but there is still not much help on the activeX funtions
Regards
(3,347 Views)
