Controlling third party .exe programmatically in LabVIEW
Hi all,
so I'm trying to integrate a third party executable (a switch box) into my LabView program. With System Exec.vi I'm able to call up the executable, and the front panel of the executable with various buttons will pop up for me to interact with. However, I would like to programmatically access those buttons in third party exe without the pop up window. i.e.  being able to switch the switch box on or off without user interaction.
From the manufacturer's notes it seems that it's possible to control either manually through the pop up window or programmatically.
How do I add parameters to the command line? So far putting " path\file.exe\" in the command line launches the .exe but on appending
"path\file.exe\manufacturer-provided command" I get an error
Thank you.
(4,430 Views)
Accepted by topic author nikvl
It will be much easier for us to fix the error if you name a third-party application, or (better) give a link to its help, which describes program management.
Now I can assume that the command should be written like this
path\file.exe manufacturer-provided command
or so
path\file.exe / manufacturer-provided command
or so
path\file.exe -manufacturer-provided command
(4,418 Views)
Just for future reference, you should always try what you want to do automatically in a manual fashion first.  In this case, it doesn't seem like you tried to execute the commands from a command line.  That would probably have helped you to solve your issue and you wouldn't have even had to come here.  🙂
Bill
CLD
(Mid-Level minion.)
(4,340 Views)
Trust me, I actually do search the forums first.... (hence knowing about the system exec in the first place)
Calling the executable was not the problem nor was interacting with it.
I was using the command line; I just wasn't aware that there should be a space for the command in the command line, which I figured out anyway on my own looking at labview examples after posting and the way I found what the actual command should look like was through trial and error because the manufacturer's help was really sparse and unclear.
I simply marked it as resolved in case another user like me stumble upon it, where the issue could be a simple one of not inserting into the command line with the correct format
(4,311 Views)
