Contructing an RS-232 interface using USB interfaces Digital IO
I've got a NI USB interfaces to work with, which has plenty of digital IO available (USB 6259)
I need to communicate via RS-232 with a few instruments, which I've already done using USB to RS-232 devices.
However, I would like to do everything on a single NI USB DAQ interface. Is it possible to use a few digital lines from the USB 6259 to create an RS-232? It seems that this would be relatively straightforward, but I haven't heard of this being done.
(2,942 Views)
Not recommended.  Voltage levels are different, no FIFO of communication, no UART that does bit sampling and error checking, no clock for data, a lot harder than you think it would be.
Matthew Fitzsimons
Certified LabVIEW Architect
LabVIEW 6.1 ... 2013, LVOOP, GOOP, TestStand, DAQ, and Vison
(2,925 Views)
