Converrt a list into frequncy of occurance
this is a simple problem but i'm sure there must be an icon to cover this.
Say i have a 1D array of numbers for arguements sake lets say:
1,1,2,2,2,2,2,36,59,100,100
how can i convert them into a 2D format that has them in the follwoing format
1,2
2,5
36,1
59,1
100,2
basically a 2D array with the value opposite the data value depicting how many times it occurs??
I've already sorted the array, so all the numbers are next to each otehr already.
Many thanks
John Pierson.
Message 1 of 9
(4,366 Views)
Hi John,
attached is a picture with one solution.
Hope it helps.
Mike
Message 2 of 9
(4,356 Views)
Use the Histogram VI in the Mathematics palette. Here is a demo VI. It assumes positive integers in your list. If the list contains negative values or non-integer values this will not work.
Lynn
Message 3 of 9
(4,341 Views)
Sorry, should have mentioned i'm running LV 8.2, any chance you could convert it from LV 8.5??
- sorry i can't read it.
Many thanks.
John P.
Message 4 of 9
(4,332 Views)
John,
Here is the 8.2 version.
Lynn
Message 5 of 9
(4,325 Views)
Hi John,
here is another version with histogram.
Mike
Message 6 of 9
(4,302 Views)
Thank you both very much, i treid to get it converted here in the institution as i know lv 8.5 can *save as* Lv 8.2, but everyone had gone home for the day already!
John P.
Message 7 of 9
(4,290 Views)
John P.
Hi John,
what do you mean? Iit should be saved for 8.0, so you can open it with 8.2.
Mike
Message 8 of 9
(4,286 Views)
Hi, sorry i meant johnston furtehr up, it won't open but its all sorted now.
chears all.
Message 9 of 9
(4,195 Views)
