Conversion Decimal Number to 32 bit floating point
In order to write to a register in a digital camera, I need to do a conversion from a decimal number to the IEEE-754 single precision 32-bit representation of this number (and also the other way around).
Does there exist a vi, which does that? Or maybe a Matlab routine?
(5,868 Views)
Yes, Mantissa & Exponent vi.
(5,854 Views)
That is not what I'm looking for. I do not need to know how the number is written in binary notation (which is what mantiss and exponent basically does) but how it is written as a 32-bit floating point number.
(5,847 Views)
"Decimal String To Number" vi
or
"To Single Precision Float" vi ?
(5,844 Views)
This should do it...
Randy
(5,829 Views)
Yes!
This works, if you set "Type" to "09" for single and for the output you select a number in I32 binary reprensentation.
Thanks a lot.
Dominik
(5,813 Views)
