Conversion from 2013 SP1 13.0.1 (32bit) to 2022 Q3 22.3f0 (64-bit)
2013 SP1 13.0.1 32-bit
2022 Q3 22.3f0 64-bit
Thank you in advance for help with this one.
(1,154 Views)
Hi ISU,
why don't you open the VI in LV2022 on your own?
(As long as you don't attach the VI no one else will do this.)
(1,149 Views)
Apologies.  I'm new to LabView and the department told me the .vi and many others can't work in the 2022 version so they are stuck using old hardware.  From the looks of it, yes, all I need to do from LabViews warnings is install the NI-DAQmx driver.  Sorry for wasting time.
(1,142 Views)
