Conversion from U32 to FXP on host side after FIFO DMA transfer
@Intaris, I see the interest of the "Reinterpret Number" FPGA Node, but in the present case you have to change sizes anyway (24bit <-> 32bit) to comply with the chosen FIFO type. But I agree that FXP representation of constants / controls / node outputs are not visible at all. LabVIEW FPGA could be improved if we had the possibility to make it visible on the block diagram directly.
Message 11 of 14
(587 Views)
Out of curiosity, where do you see the conversion from 24-bit to 32 and back? I've re-read this thread and the other you've linked to and see no mention of changes in bit width. Is this just familiarity with the device?
Message 12 of 14
(579 Views)
Because his FXP value comes from an NI 9222 analog input (Mod6/AI0), which is a FXP <±,24,5> in "Calibrated" mode, and he wants to send it via a U32 DMA FIFO. Why U32 FIFO ? Because he is also sending SENT data which is also U32, so this configuration is the most logical in my opinion.
Message 13 of 14
(568 Views)
Hi Raphael,
First test has shown this solution works 😊
Thank You for support.
P.s I promise not to multiply threads if further doubts around this matter arise.
Message 14 of 14
(525 Views)
