Conversion string from a system unit to another
Hi all i've a problem
i'm talking with an oscilloscope.
when i ask it some information like X or Y scale, it answers me a string (like 0.0016 to indicate 1.6m or 0.0000005 to indicate 500n).
I'm finding difficulties because the first string to number conversion cut me the number so i can't go on....
I want 2 number indicators:
1)  with the value with 3 digits;
2)  unit as an integer to connect to a ring array of constants (filled like mVolt,nVolt,pVolt ecc)
Can you help me?
Regards
Dario
http://www.sd-studio.it - web design agency
(3,145 Views)
Hi Dario,
you can set the formatting of your number indicators!
Maybe you try to use a format like '%3p' to show a number with 3 digits and SI unit...
You can also go this way: right-click your number indicator, select format&precision and set it to 3 'significant digits' and 'SI notation'
(3,141 Views)
Hi Dario,
GerdW is right; you can both set your indicator formatting and choose the best suitable conversion function for you.
Below there's a simple example of conversion string/numeric (double) (It's in 7.1)
Fabio M.
NI
Principal Engineer
(3,120 Views)
sorry
i've only 6.1 version avaible
tnx
(3,117 Views)
Hi Dario,
here's a picture of Fabio's vi (with small addition by me to demonstrate the number-to-string formatting):
Message Edited by GerdW on 01-10-2007 10:44 AM
(3,112 Views)
