Convert 1.235G to display 1235M
How do I display the number 1.235G as 1235M in a string display ?
I also need to retrieve the value
Keith
(3,539 Views)
Keith
Search for the dot and the letter G. Remove dot, replace G with M. Finally, use the string to decimal number function to get the value...
You can do these steps in many variations, very simple. You can even play with the string functions which use regular expressions, so you could do what you want in a single step...
What did you try so far?
(3,517 Views)
Hi Keith,
use ScanFromString and FormatIntoString:
(3,501 Views)
Thanks for the responses, however, this does not preserve the value of the original number.
I need to extract the number from the resulting string at a later time. Also, this value is written into a database, so future users will need to have the correct value
I've tried various formatting techniques, but all seem to change the original value.
I am looking for an automated way of displaying 1.235G as 1235M
Keith
(3,490 Views)
Hi Keith,
Why not?
My snippet scans the number and reformats it according to your requirement.
Can you attach a VI showing the problem of "not preserving the value"?
Why don't you keep the original string/value instead of the "resulting string"?
What have you tried? Can you attach your VI?
Why don't you keep the "original value" and only change the value for this string display?
See my snippet…
(3,485 Views)
You are CORRECT.
My Mistake. I did not try to run your code...
Kudos
(3,480 Views)
