Convert 2D Array into 1D Array with Concatenate
i want to retrieve all the rows from the 2D array and concatenate and form as 1D array. How can it be achieved. Attached a sample input and expected output format. Can someone helpout.
Message 1 of 12
(7,958 Views)
Accepted by topic author Technical_details
Hi detail,
autoindex each row, then use ArrayToSpreadsheetString. Cleanup the string using TrimWhitespace (to remove trailing EOL chars):
This was an easy homework, wasn't it? 😉
Message 2 of 12
(7,945 Views)
Hi Gerd
Wow that was a great solution. thanks
Message 3 of 12
(7,924 Views)
The same data if i require without the '-' how could i get it. Instead of 0-1-2-3 if i need to get as 0123.
Message 4 of 12
(7,910 Views)
Hi details,
use ConcatString instead of Array2SpreadsheetString…
Message 5 of 12
(7,904 Views)
Use Empty string as separator.
Qestit Systems
Certified-LabVIEW-Developer
Message 6 of 12
(7,890 Views)
No that doesn't work, it will add the default separator (tab) in this case.
Ben64
Message 7 of 12
(7,876 Views)
So let it be tab separated and add a Search and Replace with empty string. 🙂
/Y
Qestit Systems
Message 8 of 12
(7,861 Views)
Or better, change the Array to Spreadsheet string to a Concatenate strings.
/Y
Qestit Systems
Message 9 of 12
(7,859 Views)
Hi Yamaeda,
why not redirect to message #5?
Message 10 of 12
(7,856 Views)
