Convert 6.0.2 to 8.5
Hello, could someone please convert the attached files to v8.5
Also, I beleive the attached files are "written" in legacy ni-daq.Wlil this conversion process make them work with a new DAQ card, like the PCI-6221?
The previous card was an AT-MIO-16E.
Thanks in advance.
(2,405 Views)
Attached should be the 8.5 version (zipped since I have a pokey DSL connection at work).
As for your other question,  the PCI 6221 is not supported by Traditional DAQ.  Thus, you must updated the code to use DAQmx. There's lots of examples that ship with LabVIEW that show you how to use DAQmx. You can also look over: Transition from Traditional NI-DAQ to NI-DAQmx in LabVIEW and Learn 10 Functions in NI-DAQmx and Handle 80 Percent of Your Data Acquisition Applications.
(2,397 Views)
