Convert 7.0 VI to 6.1
Hi all,
as altenbach suggested (thanks a lot altenbach) I managed to save from 7.1 to 7.0 -
the problem is I am missing 7.0!!!
can someone please convert the attached VI to 6.1!
thanks
Dimitris
(2,422 Views)
Well, it does not look too good because you use a lot of express VIs, a functionality that did not exist in 6.1.
Here's the main VI in LabVIEW 6.1, maybe you can patch it all up. It will need some work. Good luck! 🙂
(2,410 Views)
