Convert ASCII output to legible English
It is under String>>Additional String Functions. It is just a thin wrapper around String>>Spreadsheet String to Array.
Message 11 of 16
(488 Views)
Message 12 of 16
(483 Views)
Swap the format string and spreadsheet string wires.
Other than that, it should work if you configured the visa session correctly.
Message 13 of 16
(474 Views)
as it was said before the termination character shall be \r (But you need to right click on the string constant and select '\' Display
add a wait time for a few milliseconds after writing to give the instrument time to respond.
According to the manual the response shall be a string of probably 24 bytes, of numbers separated by commas. You can convert it using String to spreadsheet to array , wire a constant of Integer numbers and it will convert the strings of 0 and 1 into an array corresponding to each of the parameters of the response.
Message 14 of 16
(472 Views)
do all string inputs have to be '\'
Message 15 of 16
(441 Views)
no
Message 16 of 16
(431 Views)
