Convert ASCII to 12 bit, 2 byte binary, LSB first
Hello again!
I decided to write a new VI in order to see how would the device respond to live tweaking of the values you send. Again, using the slides I would like every time that a change the value of a slide, to send the appropriate command to the device. My question now would be, how can I make labview, constantly monitoring the values of the slides and, if one is changed, to send the appropriate command?
Message 21 of 22
(781 Views)
Use a event structure.
Now Using LabVIEW 2019SP1 and TestStand 2019
Message 22 of 22
(765 Views)
