Convert Analog 14V signal to a boolean
Hi all,
I'm trying to use a proximity sensor (Panasonic GX-F/H) which switches between 0 and 14V to stop a linear motor. What is the proper way to convert the analog input singal from the sensor into a boolean?
My attempt was to connect the sensor to the analog input of my DAQ 6008 and use a comparator (signal < 10V) --> see attachement. This actually worked but it sometimes had a delay of more than 1s, what makes it impossible to position the motor accurately. Any ideas to solve this problem? Thanks in advance!!Smiley Happy
Regards
JW
(3,441 Views)
Hi Bigles,
you don't have an "analog signal" - you have a DDT wire…
Either convert the DDT signal to a DBL wire (ExpressVI functions palette: "FromDDT"…) to compare the DBL with your limit OR convert the result of the comparison from DDT to boolean value (ExpressVI function palette: "FromDDT")…
(3,425 Views)
Hi Gerd!
Thanks a lot for the help. I really appreciate!
I changed the DDT-signal with the "FromDDT"-converter. This works and finally i got a boolean signal. However, I did not help with the delay that sometimes occured. But I just figured out that the issue was due to a too high "number of samples" which I defined. Now everything works.
Thanks a lot and have a nice week
Best regards
JW
(3,415 Views)
