Convert Date/Time String to Timestamp
This should be dead simple.
Date/Time String:   3/9/2023 5:51:23 PM
Convert to Timestamp.
Why is this so complicated?
Patrick Allen: FunctionalityUnlimited.ca
(2,292 Views)
Accepted by topic author pallen
Because date and time is a very difficult topic to handle correctly!
However the principal problem is not that hard. You can use for your case Scan from String with a format string of
%<%m/%d/%Y %I:%M:%S %p>T
The real problem starts if this is not your local time zone but something else.
For a UTC timestamp you could change it to
%^<%m/%d/%Y %I:%M:%S %p>T
Other timezone handling is tricky. And you may also have to check if your date is really MM/DD/YYYY. It usually is if you use slashes as separator but it does not have to be.
Rolf Kalbermatter  My Blog
(2,289 Views)
I'd been struggling with the Scan from String examples and just figured it out.
You posted the same solution I came to.   Thanks for quick reply!
(2,282 Views)
