Convert Encoder counter value to RPM
I have a NI myRIO and an encoder which is being turned by a separate motor. I am looking to convert the counter value to to revolutions per minute. The Encoder has 5000 pulses per revolutions
I have attached a photo of the current block diagram below.
Thanks in advance.
(5,487 Views)
Hi kev,
So what is the exact problem? Which result do you get - and what do you expect?
Most often rotation speed is calculated by
speed = (encoder_current - encoder_previous)/pulses_per_rev/time_interval
Right now you know "encoder_current" and "pulses_per_rev". You also need to know "encoder_previous" and "time_interval"…
(5,463 Views)
I currently have the total revolutions of the motor over a time manually specified. I am looking for the current speed (RPM) of the motor. How would I get encoder_previous and time_interval?
Thanks.
(5,413 Views)
Hi kev,
to get data from previous iterations you need to use shift registers - as you should have learned from taking the "Training resources" offered in the header of the LabVIEW board!
"encoder_previous" is the encoder value from previous iteration, time_interval is the difference between current time and previous time…
(5,406 Views)
