Convert Engineering Notation into the SI prefix
I have a table of data with certain columns with capacitance values. The values are in string value, such as 100.00E-9. I want to display this data as 100.00nF instead.
There seems like there would be a real simple way of converting format into a number and use the format into string function to get nano, micro, or pico.
(7,052 Views)
Convert the string into a number. In your numerical indicator, right click and select Format & Precision. Select SI Notation as the format. You will see values such as 50p for pico, 100n for nano, 3u for micro, and 40m for milli. You have to add the F for nF as a string located after the numerical indicator. So you would see 100.00n in the box and F after the box.
- tbob
Inventor of the WORM Global
(7,041 Views)
I need to clarify by saying I need to reprint the original string as a string again in the table. I need to go from "100.00E-9" to "100.00nF" so I can write this in a report in Word.
Thanks.
(7,034 Views)
Hello acer,
I think that's what you need...
Converts string (with number) and unit to string with SI unit. Perhaps some fine tuning is needed.
(7,026 Views)
Thanks for both your help tbob and GerdW. I wasn't thinking clearly and didn't realize there was a format specifier for SI notation. The %p is exactly the thing I needed to reconvert number to string.
Thanks again very much,
Acer
(7,020 Views)
