Convert Hexadecimal to IEEE float
HI
I am trying to convert a HEXADECIMAL CAN message (inputted via Valuecan USB connector)into IEEE Float format.
In the VI I can read the Hex message example: 40 89 58 1E. This equates to ~4.29 volts
If I read this using the NI CAN card the set up is:
Byte Order: Motorola
Data Type: IEEE Float
Start bite: 24
End Bits: 32.
Any ideas.
Best regards
Allan Johnstone
(4,640 Views)
Hello Allan,
just use the type cast function. Have a look at the attached example.
The string control is set to hex-view, the type is set to SGL as you supply 4-byte representation. (A DBL would need 8 bytes.)
(4,633 Views)
Hi LabVIEW Community,
I will use this thread, even my problem is the inverse of the one from Allan.
I have to establish an communication to a ABB controller via MODBUS. I managed to get values from the controller and convert them to SGL values. But now I have to set values in the controller, which means, that I have to convert SGL to 4Byte IEEE format.
Any hints?
Thank you very much in advance.
(4,452 Views)
Hi Beri,
SGL are IEEE 4 byte format... You probably need to convert to an U32 or and array of 4 U8.
Also use typecast, wire your SGL to data input, wire the needed type to the type input and you should get your result as needed!
(4,449 Views)
