Convert JSON String to LabVIEW array of Cluster that contains 1DString and 2D Strings.
-- I have this JSON string that I need to convert to LabVIEW control that is an array of clusters where a cluster is: 1Darray of strings PLUS 2DArray of strings:
-- See the two attachments:
(a) JASON PACKET is provided in text file.
(b) LabVIEW VI that I tried to do but does not work
(1,072 Views)
Accepted by topic author Anthony_L
The type input just had to be modified a bit.
Redhawk
Saying "Thanks that fixed it" or "Thanks that answers my question" and not giving a Kudo or Marked Solution, is like telling your waiter they did a great job and not leaving a tip. Please, tip your waiters.
(1,052 Views)
Thank you very much!
Can you clarify what you modified? That packet is just one example of multiple packets that will be arriving in that same format.
Once I get the details of the modification I will mark your reply as 'the SOLUTION'.
It is already a SOLUTION reply, but it just needs that further clarification.'
Thank you again
Anthony Lukindo
(1,030 Views)
OK I got the modification.
You put a CLUSTER Over the Array!
(1,029 Views)
