Convert LabVIEW 8.x to LabVIEW 7.x ?
This is undoubtedly a stupid question, but here goes anyway: how do I convert LabVIEW 8.x to LabVIEW 7.x?
I have both LabVIEW 8.6.1 and LabVIEW 7.1 installed on a WinXP system, but the "Save for Previous Version" dialog only shows LabVIEW 8.x sub-versions. But I see in the discussion forums that occasionally a moderator has converted such-and-such a VI to 7.x - what's the secret ?
Thanks in advance.
(3,752 Views)
Accepted by topic author Keller
You need LabVIEW 8.6,8.0 and 7.1 to be Installed in your machine to convert from 8.6 to 7.1, from 8.6 u can convert upto 8.0 and open the code in 8.0 and convert to 7.1 simple 🙂
Balaji PK (CLA)
Ever tried. Ever failed. No matter. Try again. Fail again. Fail better
Don't forget Kudos for Good Answers, and Mark a solution if your problem is solved.
(3,750 Views)
