Convert Labview 8.0 to 7.0 please
Hi, can someone please convert this vi from 8.0 to 7.0? I do not have Labview 7.1 required for the middle step.
Thanks!
Denys
Message 1 of 10
(6,218 Views)
Try this.  Both times (8.0 to 7.1, and 7.1 to 7.0) there were error messages about certain library files couldn't be down saved.  But both times, I was able to reopen the file in 7.1 without a broken arrow.
It also grew to be a very large file so I had to zip it to be able to attach it.  There are numerous boolean indicators, express formula VI's and other stuff that seemed to make it grow large.  There may be room to improve this using clusters and arrays of booleans and sub-vi's to replace the formula nodes.
Message Edited by Ravens Fan on 01-07-2008 04:16 PM
Message 2 of 10
(6,206 Views)
Everything seems to work, thanks a bunch!
Denys
P.S. I man need to manage those booleans on an individual basis which is why I created them as indicators.
Message 3 of 10
(6,180 Views)
pls convert this vi to labivew v 7.0..
at present its saved in labview v 8.0 change it to 7.0 ...
N. Srinivasan
Message 4 of 10
(5,934 Views)
He does seem insistent on attaching his request to threads that are pretty much completed, rather than starting a new one that would more likely to get a new look.
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
Message 5 of 10
(5,923 Views)
hi,
 r u telling to create new post for this conversion???????
N. Srinivasan
Message 6 of 10
(5,918 Views)
It isn't a great idea to attach questions of your own to threads that have gone on for a while, or have been "answered" with a "solution", since many of us tend to not look at those. In particular I have seen people attach their questions to threads that were years old.
In this specific case, it probably isn't a good idea to start another thread as you have attached to two threads already, also not a good idea. I will mention to anyone that wants to assist at this point that the vi that was attached for the latest conversion appears to require having the database toolkit, which, unfortunately, I don't have installed for the necessary version.
Putnam
LabVIEW Champion
Message 7 of 10
(5,886 Views)
hi,
 here i attached the database toolkit.. whether now its possible to convert it ????
otherwise i have to re work my program from the begining...... ??
hope for good!!!!
Message Edited by Support on 10-31-2009 04:00 PM
N. Srinivasan
Message 8 of 10
(5,871 Views)
Hi srinivasan,
I doubt NI will be pleased if everyone is posting their toolkits (or "their work, where you have to pay for") on public forums.  Should I report this to a moderator? Do you own the toolkit for that LV7.0 version?
Message 9 of 10
(5,856 Views)
sorry i wont post toolkit....
N. Srinivasan
Message 10 of 10
(5,853 Views)
