Convert NI-9477 To 24V Sourcing Output
I have an NI-9477 32-Channel (Sinking Output) module that I need to "convert," to a Sourcing Output. I understand I can do this through the knowledge article below:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YI7ICAW&l=en-US
I understand that I need to add "a 'Pull-Up' resistor between the output of the I/O to a voltage source."
Output With Pull UpOutput With Pull Up
However, I don't know what that means physically. Are there any photos or more specific diagrams showing how to do this on a C Series module?
Specifically, I want to convert all 32 inputs of the NI-9477 module:
  1. What do I need to connect and to which pins?
  2. Where do my digital inputs go in this new circuit?
9477 Pinout9477 Pinout
Message 1 of 11
(4,024 Views)
Do you have a friend or colleague with any experience in Electrical Engineering?  Failing that, have you tried doing a Web search for "pull-up resistor"?  Either method should provide you with a better answer than we could give because you will know all the details of your task and can either (a) explain/show them to your colleague or (b) apply them while reading detailed descriptions and circuits found on the Web about this topic.
Bob Schor
Message 2 of 11
(3,975 Views)
I think I would just invest in a NI-9476, which is a sourcing Digital Output (has Vsup input as the voltage source for all of the outputs).
Message 3 of 11
(3,966 Views)
Hey Bob,
Unfortunately, I don't have such a person in our group. I'm familiar with a pull-up resistor, but I wanted to know if there's any NI specific documentation for using one with an NI-9477. Looking a little more online I found this circuit diagram which makes more sense to me:
https://cdn.sparkfun.com/assets/6/f/b/c/7/511568b6ce395f1b40000000.jpg
Construction:
If I understand correctly, I can use the same voltage source, but will need multiple resistors, each connected between VCC (my 24V Power Supply), and a digital input. Then the power supply GND will connect to the NI-9477 GND (Pin 28) So for the fist few inputs I would have
24V+ -> R1 -> DO0 (Pin 1) + Module Input 0
24V+ -> R2 -> DO1 (Pin 2) + Module Input 1
Operation:
As I understand, this circuit inverts the logic of the module so that the NI-9477 DO = TRUE will result in a False output. So I'll just need to invert the logic 1st.
Message 4 of 11
(3,947 Views)
Normally, I would, but this is one of those projects with more time than funds. So I'm in a work with what I have situation.
Message 5 of 11
(3,938 Views)
 Here's some ideas on driving 24V devices with your DIO...
=== Engineer Ambiguously ===
Message 6 of 11
(3,932 Views)
Thanks for the designs. However, these look more complicated than what the other diagram I posted looked like. Is what I posted earlier the "open collector," option? Is there a reason to use the MOSFET or Bipolar designs over this one?
Message 7 of 11
(3,923 Views)
Well most common DIO devices can't handle that high of voltage directly and this is how to make them do it
Message 8 of 11
(3,921 Views)
Ok, Thank you for the clarification.
Just to make sure, the NI-9477 looks like it can handle up to 60V input:
https://www.ni.com/pdf/manuals/374182b_02.pdf
For my case (24V) Will I be able handle the voltage directly?
Just want to make sure, again for my background: I'm an ME, pretending to be an EE 🙂
Message 9 of 11
(3,897 Views)
Hi JS,
It does not "look like"!
It is specified to handle an external power supply of 0…60Vdc, and it is specified to be able to switch upto 1A per channel with a max of 20A for the whole module…
Message 10 of 11
(3,883 Views)
