Convert Number to Words in LabVIEW
Hi all,
As per the title shown, i need helps on converting number to words using LabVIEW.
For example, 100 to one hundred.
Can anyone help? Thanks in advance.
Crystal
Message 1 of 10
(6,867 Views)
A simple google search will find you many algorithm in text based languages. There are two parts:
  1. parsing the number into its digits
  2. using a lookup table to find the correct word based on digit position and value, taking care of special handling of the special words for e.g. 11-19, etc.
What have you tried? What is giving you problems?
Message 2 of 10
(6,863 Views)
Hi
Message 3 of 10
(6,853 Views)
Hi 123,
@123xj wrote:
You just implement the very same algorithm in LabVIEW. Should be as easy as with text-based programming languages…
@123xj wrote:
Do you search for "ready-to-use solutions" for your homework?
Or should you learn LabVIEW by solving that homework on your own?
(An algorithm is a description on how to solve a problem - it is not a "ready-to-use solution"!)
I repeat what Christian already asked: What have you tried? Where are you stuck? Why don't you attach your current VI?
Message 4 of 10
(6,835 Views)
Hi
Message 5 of 10
(6,829 Views)
Hi 123,
@123xj wrote:
Then place all this code into a VI.
@123xj wrote:
Save the VI created in the first step using the name "num2word" and setup its connector pane.
Now you got your "command <num2word>" for simple usage…
Message 6 of 10
(6,808 Views)
Accepted by topic author 123xj
OpenG has a 'Number to Proper English Text' VI and a 'Place Number to Proper English Text' VI in the string palette.
You find OpenG in the LabVIEW Tools Network
Message 7 of 10
(6,798 Views)
Hi GerdW,
Thanks for taking time to reply my question.
Maybe you should just simply reply me there is no ready to use function in LabVIEW that can convert number to word. Thanks.
Message 8 of 10
(6,795 Views)
Hi 123,
I'm no Python expert, but I guess that "num2word" is not a part of the Python core implementation. It most probably comes with an additional toolkit/module/package (whatever they call it) you need to install…
The same applies to LabVIEW: such a function is not part of LabVIEW core, but you can create it on your own!
(Btw. your question is a perfect example why this specific function should NOT be part of a core package: there are way too many languages with way too many conversion rules out there to support them all with such a command!)
Message 9 of 10
(6,791 Views)
Hi UliB,
Thanks for the reply.
That's exactly what i need 😀
Message 10 of 10
(6,778 Views)
