Convert Serial data to image
MarkGreally wrote:  I cannot get labview to read this data in. Is is something to do with the formatting???
That usually means a serial port setting is wrong (baud rate, parity bits, number of data bits, etc).  One thing to note here: since you are dealing with binary data (non-ASCII), you should have the termination character turned off (boolean on the top of the Configure Serial Port).
Message 11 of 12
(1,254 Views)
Thanks. I will bare that in mind.
Message 12 of 12
(1,250 Views)
