Convert Thermistor Reading for PXIe 4353
I am looking for code to convert PXIe 4353 cold junction voltage reading to temperature reading. I tried the code for PXI 2527 as attached but the temperature result is incorrect. Thanks for help.
(3,090 Views)
I have noticed a little error in your code.
The formula for lrt = R1/(Vref-Vo)
But you wrote: lrt = (Vref-Vo)/R1
Could that be your problem?
Greetings and Regards,
James
James
(3,002 Views)
Accepted by topic author Dong2016
Thanks James. The calculation is correct as it computes the current.
I have resolved the issue by working with NI support. A program is attached for future reference.
(2,990 Views)
