Convert VI from private to public
Trying to make a private VI public. I clicked open the class from explorer and moved the file from private to public. Then I physically moved it from private dir to public. Class access now says public, saved the class. When I try to put it in a block diagram it is still private. What must I do?
thanks,
jvh
(3,737 Views)
Does the scope match any or all over-ride VIs of the same name?
Ben
(3,732 Views)
The Access Scope is greyed out but Public is checked.
(3,727 Views)
The two VIs did not share a common ancestor and that seemed to cause a problem.
jvh
(3,710 Views)
Accepted by topic author jvh75021
(3,707 Views)
