Convert Voltage values to Decimal values.
I need to convert voltage values/range to decimal values/range.
Example: I read voltage (range 0 to 1.0volts) form DAC and covert it corresponding decimal value (decimal value range is 0 to 16000).
0 decimal = 0 volts
16000 decimal = 1.0volts.
Thanks for the help.
Message 1 of 8
(8,382 Views)
Calculate the VLSB (voltage of the least significant bit) and multiply the DAC response by that. (VRefHigh - VRefLow) / Number of Bits, or in your case (1 - 0)/16000 = 0.0000625. So take your read back from the DAC times 0.00625. I'm curious though, 16,000 is an odd number for a DAC, they are usually a power of 2 like 2^14 (16,384). What kind of DAC do you have?
Charles Chickering
Architecture is art with rules.
...and the rules are more like guidelines
Message 2 of 8
(8,378 Views)
Thank you for your quick reply.
We are using LTC 2620. For now, we will be using the values up to 16000.
Thanks Again.
Message 3 of 8
(8,345 Views)
I'm not sure how you'd get a value of 16000 out of the 2620 as that is only a 12-bit DAC that will produce values from 0 to 4095. Here's the transfer function directly copied from page 12 of Linear's datasheet.
Charles Chickering
Message 4 of 8
(8,330 Views)
Sorry for the typo. It is LTC 2600.
Message 5 of 8
(8,310 Views)
The LTC 2600 is a 16-bit DAC.  So the max value is really 65535.  But that is from 0 to 5V.  With that rational, 1V should be 13107.
Message 6 of 8
(8,307 Views)
We need fine tuning down to mVolts.
Message 7 of 8
(8,304 Views)
The Ref is an external pin and can be wired to whatever reference he has available, which leads me to believe that his reference is set to 4.096 volts.
Charles Chickering
Message 8 of 8
(8,290 Views)
