Convert WDT to binary
In the niHSDIO pallette there is a "convert binary to WDT" but there isn't a "convert WDT to binary". Has anyone done this? Trying to save some time.
kph
(3,287 Views)
Hi!
I am working on finding an answer/explanation for having one vs. the other. In the meantime, I found a function under Programming>>Waveform>>Digital Waveform>>Digital Conversion called Digital to Binary which converts a digital waveform or set of digital data to a binary array of unsigned integers.
Tica
(3,260 Views)
Thanks Tica. I already solved it myself, but if you can find a reason why there isn't one in the palette or add it, I'm sure it would help some others.
kph
(3,250 Views)
