Convert XML row to tabulated data
In the attached VI that parses XML data, I would like to extract the tabulated data from the third row found in the "Search Results".
The Header name is "Reference scan" with tabulated data that looks like:
Is it possible to extract the data in this tabulated form?
hiNi
(2,880 Views)
Check this other forum, it seems to be very near from what you want to accomplish:
Parsing a non-standard (LabVIEW) XML file - https://forums.ni.com/t5/LabVIEW/Parsing-a-non-standard-LabVIEW-xml-file/td-p/3075412
(2,837 Views)
