Convert XML to Numeric Data
I am using an app,Sensor Node that delivers a realtime XML, which i wish to convert to true data so that I can use the numerical data. The length of data is not fixed. Please help
I am new to labview.
<?xml version='1.0' encoding='UTF-8' standalone='yes' ?><NodeId>2</NodeId><Accelerometer><Accelerometer1>-0.2059013396501541</Accelerometer1><Accelerometer2>4.879383087158203</Accelerometer2><Accelerometer3>8.47547435760498</Accelerometer3></Accelerometer><Gyroscope><Gyroscope1>0.01491415686905384</Gyroscope1><Gyroscope2>0.0031958906911313534</Gyroscope2><Gyroscope3>-0.02024064213037491</Gyroscope3></Gyroscope><Proximity>100.0</Proximity><LinearAcceleration><LinearAcceleration1>1.505866289138794</LinearAcceleration1><LinearAcceleration2>-4.389438629150391</LinearAcceleration2><LinearAcceleration3>5.768225193023682</LinearAcceleration3></LinearAcceleration><LightIntensity>42.0</LightIntensity><NoiseLevel>0.0</NoiseLevel><TimeStamp>1480865017310</TimeStamp>
(4,021 Views)
Hi Psaxena,
You might do it "manually" by simple string parsing: search for patterns like "1>" to find interesting parts in your string. Then use ScanFromString to convert the values.
Or you might employ the XML functions coming with LabVIEW…
What have you tried so far? Where are you stuck?
That's ok, we all needed to start with LabVIEW once. But you surely go through those free online resources to learn LabVIEW!?
(3,992 Views)
XML parsing is not working, it is not identifying the the UTF-8 enconding.
Parsing a string is picking only one value i need to extract all of them.
Now i am trying the String subset and Match regular command to extract each data seperately.
(3,964 Views)
Hi Psaxena,
I cannot comment on this as I don't use XML so often.
When you want to do something more than once you could create a function and call this function in a loop. This is valid for (nearly) all programming languages I heard of…
I would create a function that takes a keyword as input and outputs the data between the corresponding XML tags.
Example: the function input is "bla1", the functions searches for <bla1>…</bla1> and outputs the data between the <bla1> tags.
(3,945 Views)
Why are you not using the XML functions in LabVIEW?
They can do all the work for you.
If you any problems with code, the show us the code.
(3,939 Views)
