Convert XY data to Dynamic Data?
I am trying to perform an FFT, and some signal filtering.  However, my data is in xy format, with the x values being non-equidistant, and non-repetitive (the x deltas however are always approximatly multiples of the smallest delta).  The FFT function etc. all need "dynamic data" data type.
Message 1 of 9
(4,636 Views)
Try to resample your unevenly spaced data to have continuous spacing. Then convert it to dynamic data.
Message 2 of 9
(4,628 Views)
I am attempting to re-sample in software, by doing interpolations.  Seems overly difficalt for what I would imagine in a common task.
Message 3 of 9
(4,621 Views)
I haven't used it, but I think that this is what the Point by Point VIs are for.  This is a whole set of VIs that are for irregularly spaced data points (often from fieldpoint systems).  ptbypt is used in many of the names so it would be a good term to search for.
Hope that helps,
Bob Young
Message 4 of 9
(4,611 Views)
Try these links.
http://forums.ni.com/ni/board/message?board.id=170&message.id=80811&requireLogin=False
http://forums.ni.com/ni/board/message?board.id=170&message.id=18690&requireLogin=False
http://forums.ni.com/ni/board/message?board.id=170&message.id=127085&requireLogin=False
Message 5 of 9
(4,609 Views)
Thanks.  Here is what I came up with.  See what you think, and feel free to give me feedback
Message 6 of 9
(4,594 Views)
Could you save that as a 7.0 format file?? Thanks.
Message 7 of 9
(4,585 Views)
Try this one.  I think that I managed to save it in V7.0 format.
Message 8 of 9
(4,570 Views)
Your raw data didn't come with the file so I made a demo.
Message 9 of 9
(4,550 Views)
