Convert a file from Labview 4 to 2011
I would be very helpful if you could convert the two VIs contained in the attached file from Labview 4.0 to Labview 2011.
Thanks.
regards.
(2,856 Views)
The link at the top of the LabVIEW forum will take you to the Version Conversion board.
(2,854 Views)
Conversion done here: http://forums.ni.com/t5/Version-Conversion/Covert-file-from-Labview-4-to-2011/m-p/2646175#U2646175
(2,837 Views)
