Convert a notepad file to array
I would like to make a program that can read a Notepad file that I would make. The file consists of 2 colums, 1 column represents the temperature and the other the time.
The program has to read the file and make 2 different arrays, 1 of the temp and 1 of the time.
Does anyone know how I can make this easily??
Thanks!
Message 1 of 8
(5,224 Views)
Use Read from Spreadsheet File.vi from the file palette.  This will give you a 2D array of your data.  Use the Index Array primitive from the array palette to split the two columns.
Message 2 of 8
(5,215 Views)
If you save the file as a plain text file, then Read From Spreadsheet File.vi should do what you want.
Lynn
Message 3 of 8
(5,213 Views)
I can read the file with Read from spreadsheet. Buth I can't split it in 2 array's. How do you do it?
Message 4 of 8
(5,207 Views)
Use the Index Array function to pull each column out of the 2-D array.
Message 5 of 8
(5,205 Views)
Yes I know what you want to say buth how can i program that he first reads the first column and then the second?
Message 6 of 8
(5,201 Views)
Use the "all rows" output.  That is a 2D array.  Then use the Index Array to get the two columns.
Lynn
Message 7 of 8
(5,195 Views)
"There is a God shaped vacuum in the heart of every man which cannot be filled by any created thing, but only by God, the Creator, made known through Jesus." - Blaise Pascal
Message 8 of 8
(5,192 Views)
