Convert a string to an array of character
What would be the easiest way to convert a string "HELLO" to an array of character "H" "E" "L" "L" "O" ?
I have a way to do it with a for loop but I'm wondering if there is nothing even more simple.
Thanks in advance,
Martin
Message 1 of 23
(5,138 Views)
I think I found something easy. Still with a for loop but very small. See the attached file.
Martin
Message 2 of 23
(5,134 Views)
I can't really think of a better way to do it than this:
Hope this helps
Shane.
Using LV 6.1 and 8.2.1 on W2k (SP4) and WXP (SP2)
Message 3 of 23
(5,133 Views)
Try typecast instead. 😉
Message 4 of 23
(5,135 Views)
I just saw your answer after I posted mine.
I tried out your version and it gives the correct results, but mine is approximately 30% faster. I don't actually know why. Maybe someone could enlighten us?
Hope this helps
Shane.
Message 5 of 23
(5,125 Views)
Thank you altenbach,
I should definitely read more about typecast to use it more often.
Martin
Message 6 of 23
(5,122 Views)
Hi Altenbach,
just saw your answer too. Using the typecast is slower than the original version with making an array and setting the array to a string. The fact that it is slower simply doesn't compute with me, but I've just measured it(P4 2.8 GHz, hyperthreading).
Hmmm.
Shane.
Message 7 of 23
(5,122 Views)
Just to show I've been doing something, here are the times required to modify the entire text of "Macbeth" from a string to a string array.
My version : 27.98 msec
Martin's version : 46.88 msec
Altenbach : 71.77 msec
Can someone from NI explain why this is, as I personally thought Altenbach's version would be much faster when I saw it.
Shane.
Message 8 of 23
(5,116 Views)
For a short string of 5 characters, I get the following times on my rig (1GHz PIII):
Martin 2.5 microseconds
Me 4.3 microseconds
Shane 0.8 microseconds
For a 1MB string, I get the following:
Martin 2.2 seconds
Me 2.6 seconds
Shane 1.9 seconds
So, yes, mine's slowest. 😞 Martin, use whatever is best.
Message 9 of 23
(5,101 Views)
Altenbach,
Your code is still the nicest though ;).
I'm still left asking the question why the results are in this order. From my (obviously incorrect) knowledge of HOW this SHOULD work, I thought you were on a sure-fire winner.
Does anyone know why this isn't the case?
Shane.
Message 10 of 23
(5,094 Views)
