Convert a text file to an array, then extract a range of data points from it.
I want to do the following steps:
1. Read from a text file and convert it to an array.
         My text files are with 2 colums, like this:
          1  1053
          1.3  1044
          1.5  2033
          1.7  2444
          1.9  4335
2. Extract a range of data points from that array.
       I wanna give it an order to extract the data points that I want and output as an new array.
      The range starts when colum 1 value > 1.2, and end when colum 1 value < 1.8. (1.3 to 1.7)
      And extract the range of data from these two colums, so my expect result array is:
          1.3  1044
          1.5  2033
          1.7  2444
Can anyone help me?
I'm a new user of labview haha, Thanks a lot!!!!
(7,705 Views)
"Read from spreadsheet file" (or "read delimited spreadsheet" for newer LabVIEW) will get you the data as a 2D array.
(Your post does not show the delimiter between entries. Is it a space or a tab character?)
To get a subset, use "array subset".
(7,695 Views)
altenbach 已寫:
Thanks for ur quick response!
Do you mean the separation of colum 1 and 2 in the text file?
The separation between colume 1 and 2 in the text file is like this.
Thanks!
(7,693 Views)
OK, your column seperator is the tab character. This is the default, so you don't need to wire it.
(7,643 Views)
Accepted by topic author Ying88827
Again you still have not mentioned your LabVIEW version, but here's one simple solution.
(7,607 Views)
