Convert a vi written in LabVIEW 5.1for use with 8.5?
Is there any way to successfully open and convert a vi written in LabVIEW 5.1for use with 8.5?
Message 1 of 11
(3,729 Views)
It needs to be opened and saved with an intermediate version, like 7.1/8.0. If it's just one VI or a small set you can post it here and someone will likely do it for you.
Message Edited by smercurio_fc on 05-30-2008 02:07 PM
Message 2 of 11
(3,727 Views)
That was a quick answer.  Thank you.
I don't have access to an older version of LabVIEW.  It is only 1 small vi.  How can I paste it here?
Thanks again.
Message 3 of 11
(3,719 Views)
When composing your message at the bottom there's an attachment section. Click the Browse... button to find the file on your hard drive, and the Submit the post. Note: If you click the "Preview Post" link that will lose the link to the attachment and you will need to resubmit it.
Message Edited by smercurio_fc on 05-30-2008 02:30 PM
Message 4 of 11
(3,715 Views)
OK, I didn't scroll down far enough.  Thanks.
Well, OK, here it is.  If anybody has an older version of LabVIEW, could they please do a quick conversion so I may be able to open this vi with 8.5?  It was written in 5.1.
Thnak you,
Bob
Message 5 of 11
(3,709 Views)
Here you go in 8.2.
I noticed it's doing some Excel stuff. You may want to take a look at doing this with ActiveX rather than DDE. You can take a look at the shipping examples (there's a couple showing how to use ActiveX to call Excel), as well as the examples in the Excel board.
Message 6 of 11
(3,707 Views)
OK, I'll take a look.
What I am trying to do is open this small XL sheet, read 1 cell out of it, do a bit of math on it, and write it back to the same place as the original content, and save the spreadsheet.  The reading and math is going OK, but I am having trouble getting my new figure back into the cell so I can save the whole thing.
But I will check out your samples.
Message 7 of 11
(3,703 Views)
The implementation you have may only apply to a specific version of Excel. I don't really know since I've never used DDE to read/write Excel.
EDIT: Note: An ActiveX implementation will also be for a specific version of Excel, as Microsoft often changes the ActiveX interface when it releases new versions of Office products.
Message Edited by smercurio_fc on 05-30-2008 03:21 PM
Message 8 of 11
(3,701 Views)
I'd have the same request. I need it for tomorrow and I'll be very grateful for converting it
Message 9 of 11
(3,644 Views)
Hi devoreaux,
here it is for LV71, but there are three sub vi´s missing.
Mike
Message 10 of 11
(3,641 Views)
