Convert an 8-bit grayscale image into an RGB image
To convert an RGB image into an 8-bit grayscale, using Vision Assistant, you would need to convert from the RGB color space to the HSL color space, and extract the luminance layer.
Is it possible, within Vision Assistant, to convert an 8-bit grayscale image into an RGB image by applying the gray level pixel value to the three color components: red, green, and blue?
Mensaje editado por ispbarum
Message 1 of 14
(14,389 Views)
Hi ispbarum,
to convert an 8 bit grayscale image to RGB you only need to write the value to all three components. If all values R,G and B are equal, then you get gray as color.
Hope it helps.
Mike
Message 2 of 14
(14,356 Views)
In the Vison Utilities>>Image Management pallete there is a IMAQ Cast Image function.  You should be able to use this to convert from U8 to RGB U32.
It's weird that you can only change to other grayscales in the Vision Assistant.
Randall Pursley
Message 3 of 14
(14,346 Views)
is it possible to do that without the vision module?
I work with a USB camera and the resulting array. I want tocreate a RBG image which will be the overlay of the three images.
Thanks for your help.
Sébastien
Message 4 of 14
(12,548 Views)
You already attached some code. Does it work?
Message 5 of 14
(12,541 Views)
Yesn, I've attached the file in the 2012 version.
Maybe I can try with the v.8
Message 6 of 14
(12,539 Views)
I was just wondering if you are asking a question or providing a solution. Your post read as a question so I wasn't sure.
You can eliminate the subVI and FOR loops as follows (don't kow if it is faster or slower ;)):
Message 7 of 14
(12,534 Views)
Thanks, yes, it's a question!
With your solution, the resulting image doesn't display the overlay of the 3 images.
Message 8 of 14
(12,529 Views)
All you need is "draw unflattened pixmap" and send it to an 2D image indicator. This is part of plain LabVIEW, no vision module needed.
An intensity graph is not suitable to display an RGB image.
Message 9 of 14
(12,516 Views)
I am working on image dehazing using labVIEW .I somehow manage to do the dehazing in grayscale ,now how do I convert the dehazed image to view in rgb I have used extract color plane on the original image then tried to replace it with replace color plane with grayscale image as source still it is not converting please help , I am new in this field.
Message 10 of 14
(4,123 Views)
