Convert an Array of Variants of Enums to an Array of Enums
I have a piece of data that is a 1D array where the array element is a variant of an enum.
How do I convert this to an array where the array element is the enum, not a variant?
The only access I have to the enum properties are through the variant of the enum.
I can't just drop a constant on the block diagram and wire it to the Variant to Data VI.
Getting just the numeric values, or converting them to the string values is not enough.
I need the data type of the array element to match the original enum.
Message 1 of 13
(4,469 Views)
AFAIK, enums are defined at edit-time, not compile time, so you can't "make a new enum" on-the-fly like you're trying to do. You can probably make a ring though. Would that work? What exactly are you trying to achieve?
Message 2 of 13
(4,464 Views)
This is the "safe" way to do it.  I don't know if you can directly convert an array of variants into an array of enums.
Bill
CLD
(Mid-Level minion.)
Message 3 of 13
(4,413 Views)
I suppose, you are looking for the now deprecated
"..National Instruments\LabVIEW 2019\vi.lib\Utility\GetTyp.llb"
this .llb can be used like shown in the following example from this source
"GetTypeInfo.vi"and  "GetNumericInfo.vi" can be replaced by the counterpart of the Data Type Parsing VIs
Message 4 of 13
(4,408 Views)
I don't think they are deprecated.  They are there in LV 2020.  I guess I missed the intent of the original post, though?
Edit: Maybe those are old versions of the VIs?  There are current VIs with the same name but different icons where you expect them in the palette.
You know, I should just read more carefully.
Bill
CLD
(Mid-Level minion.)
Message 5 of 13
(4,383 Views)
Deprecated doesn't mean they no longer exist or can't be used.  It means NI no longer desires for them to be used.  That  they might be superceded by a newer version.  And there is a risk that at some point in the future they will disappear.
The red X on the icon indicates this status.
Message 6 of 13
(4,371 Views)
We crossed posts.  They are deprecated and replaced by new Vis with the same name, just as he showed - and said.  And as you said, also.  Which means I didn't read his post correctly.
Bill
CLD
(Mid-Level minion.)
Message 7 of 13
(4,357 Views)
Here is a better explanation of my issue.
The VI requires the OpenG Toolkit to run.  It is written in LV2018.
Message 8 of 13
(4,283 Views)
I don't need to define a new enum.  I need to set new values in an array of existing enums.
I use a ring control for the user interface, but I need to convert the user input back into the correct enum data type.
I added a VI to this discussion to demonstrate my issue.
Message 9 of 13
(4,281 Views)
This is definitely the most straight forward way to fix the issue.
But it would mean that I need to maintain a case structure of all the enums that could possibly fill the array.
Enums are added and subtracted all the time.  I do not want to maintain that case structure.
All the data type information I need is carried with the variant, I just don't know how to build the object correctly.
I added a VI to this discussion thread to illustrate my issue more clearly.
Message 10 of 13
(4,277 Views)
