Convert and Display 1D array of Bits to a hex string
I'm a beginner to Labview. My VI has used the "Build Array" function to index specific array elements of a larger 2D array and put them into a 1D array. The array, for example, contains "0 0 1 0 0 0 1 1". I want to display this as a hexadecimal string on the front panel as an output.
I could not figure out a suitable function to do this. My last attempt is shown below in which I use the "Array to Spreadsheet String" function, but my front panel still displays the bits.
(4,509 Views)
Accepted by topic author MBen11
Hi MBen,
compare the 1D array with "unequal to zero" to get a boolean array. Then use BooleanArrayToNumber to convert to an integer number. Now use FormatIntoString with any format code you like...
(4,487 Views)
1) Check the endian order and reverse array if needed
2) convert to boolean array with "Not Equal To 0?"
3) "Format Into String" to display the way you need.
(4,484 Views)
Edit: Got it - Thanks for the help!
(4,446 Views)
As you can see the Not Equal to 0? does not need to be in a loop.
(4,442 Views)
